Announcements
The future of Electronics at Autodesk is Fusion, click here to visit the Fusion Electronics forum. Eagle and the Eagle Community will be End of Life on June 7, 2026 - click here to see the announcement.
Opening Old Eagle Binary Files in Newer Software
amrhesham042
Observer
amrhesham042
Observer
Observer
I have some schematic files that were created in an older version of Eagle (likely version 5.6 or earlier). When I try to open these files in the current free version of Eagle, I get an error stating:
> "Invalid file format"
From my research, I understand that Eagle versions prior to 6.0 used a binary format, while newer versions (6.0 and later) use XML. Unfortunately, I no longer have access to the older version of Eagle to open or convert the files.
I’m looking for a solution to open or convert these files to a format compatible with modern Eagle or KiCad. Here’s what I’ve tried so far:
- Opening in the free version of Eagle (failed with the error above).
- Using KiCad’s import feature (failed due to binary format incompatibility).
Could anyone guide me on:
1. Where I can find a trusted version of Eagle (5.6 or earlier) to open these files?
2. Any tools or scripts available for converting binary Eagle files to XML?
3. Whether Autodesk offers a service or tool to help with such conversions?
Any help or advice would be greatly appreciated. Thank you
jorge_garcia
Hello @amrhesham042,
Newer versions of EAGLE can open older binary format files. This type of error likely means that you do not in fact have  EAGLE files. What convinces you that you have EAGLE files?
It important to note that file extensions are not proprietary, so the fact that you have an sch and a .brd files doesn't mean you have EAGLE files. I opened that files in a text editor and these files are actually text based and I can tell you conclusively these are not EAGLE files.
Let me know if there's anything else I can do for you.
BEst Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
amrhesham042
Observer
Observer
Hello @jorge_garcia ,
Thank you for your response. I initially assumed these were EAGLE files because they could be imported into KiCad using the "Import Non-KiCad Project → EAGLE Project" option. However, when I attempted the import, KiCad displayed an error stating that the files are in binary format, while it only works with XML-based files.
A friend also tried importing them into Altium and received a message suggesting the files needed conversion to XML format using an older EAGLE version. I then tried opening them in EAGLE versions 5.6 and 6.6, but both returned an "Invalid data" error.
Since you've confirmed the files are text-based and not EAGLE files, could you recommend any programs or tools that might help me identify or open these files?
Best regards,
jorge_garcia
Did you try opening them as just normal KiCAD files? KiCAD uses a text based format so they could be just KiCAD files. I would try to ask the original designer if that is an option.
Best Regards,
Jorge Garcia
amrhesham042
Observer
Observer
Hello @jorge_garcia
I did try to open them using Kicad but the files don't appear. They only appear if I try to import them as an Eagle project. I got the designs from here UPsat ADCS Hardware.
Best Regards,
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
