In Eagle 8 objects always got highlighted when selected. Also, in "show" mode wires were highlighted when selected. In Eagle 9.1.3 nothing is highlighted anymore at all. Very inconvenient. Is this a bug? Is there any way to fix it?
To clarify, highlighting works fine in layout but doesn't work in schematics anymore the way it used to work in v8.
im going to say the high-lighting is terrible... I can barely see it
this is using the DEFAULT settings, moving from the defaults is a cat mouse game
as I can never find a perfect setting... other than use OLDER EAGLE (which isn't going to happen)
if you look at this image, im high-lighting 5v, you can HARDLY TELL
its prob releated to being a white screen
Eagle has to work RIGHT out of the box, with no "color" tweaking
cause the setting works good in the board view (black screen)
setting the highlight % lighter really makes it WORSE
there are settings, look at the menu; Options->Set
you will see highlighting
but I cant really find a setting im happy with, as one looks great on the PCB but then not so on the Schematic
im sure its related to background color, I do white for schematic, and black for PCB
which I think is default
mitch
Oh, thanks a lot, Mitch. I set it to high contrast and highest hue, now highlighting is bright purple. Great, problem solved!
Yes, but how do you set high contrast?
1. Go to Options->Set...
2. Check the High Contrast checkbox
3. I set Hue to about 25% for a nice, bright blue color.
(I expected this would be under the User Interface option, so I missed it the first time I tried to set high contrast)
Really wished when you used the 'Show' function on a net it would make it flash instead of just highlighting it as a lot of times I barely can see it highlighted.
