I am using the Remove All Non-Functional Pads option for my PCB and several annular rings on inner layers are being removed that should not be removed. Some vias and through-hole pads are working fine, but others are not.
Here is a screenshot that shows connections between the top layer and an inner layer.
Here is the preview from the CAM Processor for the inner layer that shows large circles at the end of the traces for the inner layer.
And here is the generated Gerber file. Note that the bottom two circles are smaller. In fact, they are the same size as the drill.
It would be one thing if none of the vias did what they were supposed to do, but some do and some don't. What is going on?
Solved by HelenChen-ElectronicsQA. Go to Solution.
That's definitely not what is supposed to happen! We will investigate and see what is going on. Thanks for reporting this.
Can see a symptom of this happening on the inner layers of the design (without going to the gerber step ... although I did just to check). FWIW, these vias are not near any polygon boundaries. Also running the latest update.
Hi @danSZGAT , @gwagnerJXG2J ,
Hope all is well.
Much appreciated for reporting this issue to us ago.
Good news that we have put a fix about it in the latest Fusion build 2.0.19725 which was live yesterday.
Could you please upgrade to the latest version to have a check?
Please feel free to let us know if you need further assistant.
Thank you.
Best regards,
Helen
Tested my simple example with the latest SW. Fix seems to work in my case. Image of the same area below. Plane is no longer collapsing into the area where functional pads should be.
Hi @gwagnerJXG2J ,
Much appreciated for your confirmation with the fix!
Please feel free to let us know if you need our further assistant.
Hope you have a great day.
Best regards,
Helen
