Need Eagle help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is anyone here familiar with Eagle and also the F360 integration?
I am very new to Eagle and trying to figure out what would be the best way to design some components.
The first is an assembled PCB that will be going on the main PCB.
https://www.diyautotune.com/product/microsquirt-module-v2-2/
Using these headers.
https://www.diyautotune.com/…/microsquirt-module-hardware-…/
Now the headers are in Eagle but I will need to precisely position them relative to each other and to the mounting holes.
From what I have gathered about Eagle it looks like this would be a massive PITA.
Could I lay it out in F360 then import it into Eagle? Or is there a fast efficient way to do this in Eagle?
I will also be adding this header.
http://perfecttuning.net/…/toyota-supra-7m-gte-2-rows-52-pi…
Which needs to be very precisely positioned on the board.
I modeled the circuit board in F360 off a 3D scan and not really knowing what I was doing I modeled the holes for this header into the circuit board. They are perfectly located but it looks like I need to have it in the Eagle library so I can use it for a schematic and run circuits to it. Or is there a way to run circuits to holes modeled in F360? If not then what would be the easiest way to design this in Eagle? Again from what I have seen it looks like it would be a nightmare to design in Eagle and even once I did I don't see any way to dimension it's position.
