I have made a 3.3v polygon on the layer 15. It will not fill. I made a gnd polygon on the 2nd layer and it does fill. What am I doing wrong?
Polygons have a "rank" in Eagle, which determines which one takes priority if they overlap. If your 3.3V polygon is a lower rank than another polygon on the same layer, it won't fill correctly.
Hi @jimlswift,
I hope you're doing well. A polygon won't fill if it has nothing to connect to(orphan). Try placing a via that connects to 3.3V within the boundary of the polygon. It should fill.
Let me know if there's anything else I can do for you.
Best Regards,
