Hi @Anonymous,
I hope you're doing well. Thanks for including the picture that is always helpful. The terms you used are good but because EAGLE has an exact match search they are too specific to be useful. Here's why:
If you just type the word switch, EAGLE will only search for the word switch specifically. It won't find switches, or other useful combinations that a search engine might infer from your initial string. In order to generalize the search you have to use wildcard characters, eagle has two the * and ?. The * is the most general of the two so as an example instead of typing switch, type:
*switch* and press <enter>
The * character matches any character any number of times, so what the above string translates to is "It doesn't matter what characters are at the beginning of the term or at the end as long as switch is somewhere in the Device name, description or attributes this is a valid result and I want to check it out".
Another example would be *555?, if you search for this you'll get results like:
NE555D
LM555N
The ? allows for any single character to be matched so the above search string wouldn't find something like LM555NED. If you wanted to find this last made up part number you would search *555*.
I hope this is helpful, in summary you want to search for *switch* or *push* or *button* and then refine from there. Check out the switch libraries that come with EAGLE. Specifically switch-omron, it has a couple of switches that are very similar to your picture.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Product Support Specialist for Fusion 360 and EAGLE
