Missing "Edit" button for 3D package in circuits.io
In circuits.io some 3D packages can't be edited, the "Edit" button doesn't exist.
I created a new library for connectors (from con-ptr500 library) and i can't edit somo 3D package.
Thanks for help and sorry for my english.
 Edit button OKEdit button OKNot Edit buttonNot Edit button
jorge_garcia
Hi @Anonymous,
This is a known limitation. If you copy from EAGLE's built in library, those assets belong to autodesk and can not be modified. What you have to do is change the package a little within EAGLE, doing this will cause library.io to no longer recognize the association to Autodesk's built-in content and you will be allowed to assign your own.
We want to make this process easier and will be adding functionality that will allow you to assign your own models without having to do the workaround mentioned above.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
