@Anonymous wrote:
Has anyone made any libraries for Microsemi FPGAs? I am specifically looking for the ProASIC3 FPGA parts in Eagle. I have access to Altium at work but my colleague prefers Eagle. I was hoping we don't have to create the 208 pin part from scratch which is a lot of work.
Creating a 208-pin QFP part isn't a lot of work. I've created much larger BGA parts and they don't take too much time once you know how to create parts properly. I've written a tutorial series on library part creation in EAGLE over on element14. I'd advise you to check it out if you need to create parts in future.
https://www.element14.com/community/docs/DOC-88188/l/eagle-tutorial-series
Also, from what Jorge is saying it looks like there are some big advances coming in the tools EAGLE provides for creating parts so this should get even easier in future.
@Anonymous wrote:
No, it doesn't exist I was told. I switched to use Altium as it has the ProASIC3 libraries ready to use.
I'm actually quite surprised you consider changing to an alternative ECAD tool less of a daunting task than creating a single library part. I suspect if you continue with Altium you'll end up in the same situation somewhere down the line where they don't have a part you need. What will you do then?
Best Regards,
Rachael
