Mapping models for simulation
I'm trying to simulate a schematic in EAGLE. So i'm mapping the components, how do I know which models go to what device? I looked up online and an LED is modeled under DMOD.mdl. How am I to know if that is correct or that it goes to an LED? Additionally i'm looking to map a potentiometer but I have no idea what model to use to map this device. How would I figure this out?
jorge_garcia
Hi @Anonymous,
I hope you're doing well. Instead of modeling a potentiometer directly you are better off using two resistors and adjusting their values, for most applications that's all a potentiometer is. The DMOD.mdl file is just a standard silicon diode model, for LEDs you would need the forward voltage to be higher so if you need the sim to reflect that acurately you are better off finding a SPICE model from a manufacturer.
Try to use standard models whenever possible, if those aren't available then you'll need to get models from the manufacturer.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
