- Mute
- Permalink
- Report
I create a library to work in one projects with 2 boards/schematics. When I finish the project I decided to create the managed library to make the 3D model of the boards in Fusion 360.
In the managed library I added without problem all the 3D models by adding a step file in each component. Then, I update the library in the first board and create the new Fusion 360 model. Everything was ok with this board. When I tried to create the new Fusion 360 model with the second board. The second board was not linked to the managed library but rather to a unmanaged library with the same name. I check the libraries (In Library Manager->In Design Tab) and I see the two libraries with the same name and the unmanaged library has a warning symbol with the legend "Library unavailable". In the "In use" tab I only see the managed library.
I have updated the managed library in all possible ways but still not working.
Why can I do to update/link the managed library?
