EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Long hole pad
1 REPLY 1
r.viol
590 Views, 1 Reply
Long hole pad
Hey,
is there an easy solution to implement a long hole pad to a footprint?
Green would be copper and the inner white area the long hole.
1 REPLY 1
JamesLE32J
in reply to: r.viol
Hi @r.viol,  you need to create pads of the required shape and then on the Milling Layer (layer 46) you draw the cut out shape.
Confirm with your board house that they read this layer correctly.
Have a read of this thread:
https://forums.autodesk.com/t5/eagle-forum/slot-for-usb-connector-tabs/m-p/8287655
