Dear all,
I am designing a board in Eagle that has two female 16 pin headers. I have my grid set to 2.54 mm and everything seams to be OK on the screen (board design).
When I go for printing my board, despite I set the scale to 1, there is a difference in the pad distance, regarding the 16 pin header.
I don't know if the problem is related to the setup or it is a printer issue. I have tried in two different laser printers and the problem remains. I have tried to print directly from Eagle and saving first as PDF. Same issue on the paper.
If someone can give me some clue to solve this problem I would appreciate.
Thank you.
Best regards
Duarte
