EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Is it possible to run ipc-d-356a.ulp from terminal?
4 REPLIES 4
432 Views, 4 Replies
Is it possible to run this specific ULP from a terminal? I have tried
eagle.exe -CRUN myboard.brd "ipc-d-356.ulp"
But I get weird popups.
Fred
4 REPLIES 4
jorge_garcia
Hi @Anonymous,
What do the pop ups say? There may be errors and you may want to be aware of those.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
in reply to: jorge_garcia
Hi Jorge,
1) When I try eagle.exe -CRUN "ipc-d-356.ulp" myboard.brd
Eagle opens, then a ULP editor opens the actual ULP
2) When I try eagle.exe -CRUN myboard.brd "ipc-d-356.ulp"
Eagle opens, then opens "myboard.brd", then opens the windows that appears when you click on "ULP" (where you select the ULP you want to run).
jorge_garcia
Hi @Anonymous,
Let's try to isolate the problem. If you open the board in EAGLE's GUI and run the ULP does it work perfectly? Because if the ULP fails in that scenario then we have to start troubleshooting there.
Let me know if that works.
Best Regards,
Jorge Garcia
Hi Jorge, sorry for the delay.
I have no problem running the ULP from Eagle. I'm trying to automatize the steps we do at gerber package generation, which involve running this ULP and some others.
