using eagle V7.2 on windows 10.
I have a Top side SMD part with a GND pin connected to my schematic GND net, I created a polygon on the bottom side of the PCB and named it GND.
when selected, it and the SMD ground pin highlight, but I see no connection to the bottom polygon on the board layout after ratnest is done.
how do I connect this pin on the top to the polygon on the bottom?
Solved by rachaelATWH4. Go to Solution.
You need to add a via to get to the bottom side.
VIA 'GND'
Then go into ROUTE mode and route the GND pin of the IC to the via.
Best Regards,
Rachael
VIA 'GND'
Best Regards,
Rachael
