My Eagle software did not lunch after installation. I tried many times.
Solved by one-of-the-robs. Go to Solution.
Hi @Anonymous ,
I hope this message finds you well. Could you provide more information? After trying a few times check the Windows logs and see if there are any reports of errors. The link shows you the instructions to check the logs.
https://www.cyberlink.com/support/faq-content.do?id=10449
Let me know if there's anything eles I can do for you.
Best Regards,
Hi @Anonymous ,
Best Regards,
Thank you for your time @jorge_garcia .I uninstalled and reinstalled it again but same issues occur. It loads the initial Eagle logo/image then stops. I have attached the error message gotten from event viewer.
The error report mentions LIBEAY32.DLL
A search for that on this forum shows up this knowledge base article and others. Have you tried the solutions in there?
