Import Polygons
b.schanzVKVZ6
Observer
Observer
Import Polygons
b.schanzVKVZ6
Observer
Observer
i need to import curved surfaces  as polygons into eagle. We need it because it is necessary to have the same contour like a other design. This was not drawn in eagle.
The file is as a dxf. file .
With import-dxf-1_6.ulp / import_dxf_polygons.ulp  it is not possible to integrate curved surfaces.
Is there any way to integrate that in eagle?
Thank you
jorge_garcia
Hi @b.schanzVKVZ6 ,
I hope you're doing well. If the shapes on the DXF are closed contours then you can bring them in and then right click on those contours and convert them to polygons.
That's the best workflow I can provide for now.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
