import a file
import a file
import a file
How do I import a file from Eagle 8.5 into Eagle 9.2
Thanks everyone Ken
odinrizhanin
Hi @Anonymous
Do you mean, that file created in Eagle's older version, doesn't want to open in Eagle of newer version? - from my experience, it has never been a problem (rather it's has some problems in other direction - older versions doesn't support some features, saved in files of newer version)
one-of-the-robs
Yep, as @odinrizhanin says, you can just open the file. It works with files from Eagle versions back to v5 - it may work with V4 files but I've got a whole slew of V4 libraries that crash V8 onward (and maybe V7) unless I open and re-save in V5 first. No problems with V6+ files that I've seen.
Ok- my fault , had the wrong path .
Thanks everyone Ken
