How to get rid of title frame
salesMUBBN
salesMUBBN
I am having trouble saving a design as a block. It is saving the title frame as well as the circuit.
I did try to save selection as design block but cannot get that working.
The software is version 9.3.1 premium.
jm2morri
The title frame, like everything else, is selected by selecting its origin "+", which for a title block is in the bottom-right corner.  So start the delete function (typing "del" is one way to do it, or click on the command button) and then left-click the bottom-right corner of the frame.  You'll need to click within whatever your snap-distance is set to -- usually within a grid mark.
You can use group to do it as well and then delete the group, but that is more complicated than it needs to be.
Cheers,
James.
James Morrison
Embedded Design Services using EAGLE
Stratford Digital Inc.
