how to generate a netlist showing both edges of a net, in Eagle?
kliJSK36
kliJSK36
Hello, I am trying to generate a netlist showing both edges of a each net in my schematic.
I've noticed that "Export->netlist", shows only one side of the nets, in a list.
and "file->run ulp->net/bus labeling" shows me a message in other language, I think its in German
"Selektieren Sie zuerst mit GROUP die NET/BUS-Wire". I've translated it to English and it says "First select the NET/BUS wire with GROUP"
I don't understand what does it mean. and if it is the way to achieve what I'm trying to get.
Hope someone would help.
jorge_garcia
Hello @kliJSK36,
I hope you're doing well. Could you clarify what you mean by both ends of a net?
A netlist will list all of the nets in the design and then under each one reference all the locations where that net connects. In other words all the nodes the net connects to are already listed in the netlist.
If you can elaborate on what you are trying to do I think I can help.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
