- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello All,
About a year ago I had made a design in Eagle 7.x making use of the hierarchical design modules as coming from Orcad/Altium tools this was a very powerful technique for more complex designs. After completion of the schematic capture I had found out that in board layout all components were prefixed with their Hierarchical module name (this resulted in reference designation 10+ characters long, which was obviously unusable on the PCB) I got around this by naming my modules in increment values 1->9 so that prefixes were limited to x: (ie 2:U1).
A year later I find myself modifying this design again and having continued issues and frustration fitting these unnecessary silk screens in sensible places on the PCB. I know I will be using this design a number of the times in the future and I am hating the realization that I will have to deal with this every time I modify the design for a new PCB. There is complex routing on the PCB (FPGA, DDR RAM, etc.) so it would take about a week of my time to copy the schematics over to a non-hierarchical design and re-route (which I simply cannot afford to do).
/rant
Anyways now to my question... is there a relatively quick method to take a hierarchical design with a number of modules and flatten it so that all components share the same numbering pool and are not prefixed with their module name?
Thanks, any suggestions would be appreciated.
