EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
How to design a slotted hole by Eagle.
3 REPLIES 3
sankakumusubi
491 Views, 3 Replies
Please tell me how to design two long holes of 0.7 x 3.1 mm at the left end and the right end in the figure of the URL below.
http://up-img.net/img.php?mode=png&id=16411
Tags (1)
3 REPLIES 3
Sadly it's not possible with EAGLE 😩😡, I asked this function from a long time but still not possible.
Sorry.
Best ad stay safe
jltharin
in reply to: sankakumusubi
Hi all!
Of course this is possible but the way to do it depend a lot of the manufacturer.
I created one in the past... Below step to do it BUT it's important to check with your manufacturer if it works!!!
- First place an pad with a drill smaller that the cutout needed and a diameter smaller that the final slot pad you need.
- Draw in polygons of the final slot pad (copper) in all copper layers (if you do only on TOP and bottom, the inner layer can't be fine connected...)
- Then draw a bigger polygon for tStop and tStop
- Then draw the slot cutout into the polygons in mil layer. (This Mil layer must be send to manufacturer to realise the cutout in the slot pad)
I put a library in attachment with the part I used if it can help.
Good luck and have a nice day!
jltharin
RitchieParis
in reply to: jltharin
Thanks for your reply,
But when I tell that EAGLE don't do that, I mean natively !! for sure with some methods it's always possible to do but all the CADSOFT do more simply and natively and quick.
But thanks.
