EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
How to create holes without tstop bstop or remove tstop bstop in holes?
1 REPLY 1
witawat57
632 Views, 1 Reply
Hello
i make pcb panel and add hole but with tstop and bstop. i need remove it
if i user drill but not show in Gerber
thankyou
1 REPLY 1
RichardHammerl
in reply to: witawat57
Hi @witawat57
HOLEs always have a solders top mask. It's created automatically by the settings in the Design Rules.
If you set the value for Solder stop = 0, solder stop mask had the same size as the drill diameter.
But this setting is valid for all pads/vias/holes and SMDs in you layout.
Maybe this helps...
Richard Hammerl
