Announcements
The future of Electronics at Autodesk is Fusion, click here to visit the Fusion Electronics forum. Eagle and the Eagle Community will be End of Life on June 7, 2026 - click here to see the announcement.
How to create a footprint with thermal vias
I'm using EAGLE 9.4.2 on a MacBook Pro Mojave.
nRF52832_qfaa_dcdc_reference
https://github.com/NordicPlayground/nrf5-eagle-reference-design/blob/master/Library/Nordic_nRF.lbr
When using Nordic Semi's library, the footprint already had a thermal via drawn from the footprint.
It says it used a "Pad". For this case, the chip's pad has to be connected to GND. So this is a thermal via connected to GND.
May I ask two questions, please.
First, just like this Nordic Semi's library, how can I add this "Pad" as thermal vias?
I hope this via can work with 2/4/6 layered PCBs.
Second, when I use a footprint library which I need to add the thermal via manually, how can I add thermal vias on the BRD file? I get DRC errors when I add a via directly on the pad.
I hope this via can work with 2/4/6 layered PCBs and I'm using the OSHPARK's design rule, by the way.
https://docs.oshpark.com/design-tools/eagle/design-rules-files/
Replies (7)
jorge_garcia
Hello @Anonymous,
I hope you're doing well. Generally, you want to add thermal vias in the library, you can add them to the board but you will always get DRC errors.
In the library, you can form thermal pads using just normal through hole pads. Instead of using a large SMD for the thermal pad, draw a polygon on the top layer and make sure to duplicate it on the tStop layer so that the copper is exposed. Place the thermal pads within the boundary of the polygon. Once you have completed the footprint go into the device editor and make sure to connect all of the thermal pads to the pin that the thermal pad represents.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Dear Jorge Garcia
I appreciate your help, sir. May I ask about
- "you can add them to the board but you will always get DRC errors. "
In other words, if I add thermal vias in the library, do I get NO DRC errors?
- I'm new to EAGLE 9. May I ask how to draw this polygon in detail, please?
A. "draw a polygon on the top layer and make sure to duplicate it on the tStop layer so that the copper is exposed. "
B. "Place the thermal pads within the boundary of the polygon."
I'm confused whether you mean to draw a polygon to fill a copper pour or to draw the thermal via.
jorge_garcia
Hi @Anonymous,
Typically you can avoid DRC errors with this method(or get very few). This method requires using the arbitrary pad shape feature of EAGLE where you can using a polygon(copper pour) as an extension of an SMD or through-hole pad. So what you do is you draw the thermal pad using a the polygon command, don't use an SMD. Then within the boundaries(the outline) of the polygon you place all of the thermal pads using the PAD command. EAGLE will see the polygon as an extension of the thermal pads. This is what helps minimize the DRC errors.
In the device editor you then assign all of the thermal pads to the same pin on the symbol.
Let me know if you continue to run into issues.
Best Regards,
Jorge Garcia
Thanks. In summary, you are saying
- for the thermal pad draw
top layer
tStop layer
- "you place all of the thermal pads using the PAD command"
You are mentioning about the circle shape vias as the thermal pads, right?
May I ask what layer should this PAD has to be placed?
top/tStop/bStop/bottom
I think for this case, the solder mask opening shouldn't be removed so I'm worried what layers to place this pad.
jorge_garcia
Hi @Anonymous,
I hope you're doing well. You are correct on the layers for the thermal pad, top and tStop. For the PAD you don't have to worry about the layers, EAGLE automatically places all the features on the correct layers.
Best Regards,
Jorge Garcia
Hi Jorge, would we need then to place the vias in the schematic too? is there a smart way to place multiple of them with say just changing the naming to an array style: inp[0:15]?
JamesLE32J
Hi @Anonymous,  In the above example if you have connected your thermal vias correctly they will be connected to your symbol's GND pin and so you only need to ensure the GND pin is represented in the symbol.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
