Well, to me this feature "Continue adding your DB ideas to this thread and I will make sure dev team take a close look", is worth paying for.
In my previous Cadsoft experience, whether you paid or not, you had the right to be ignored and your ideas were lost in the flow of time.
Reading the forums, I noticed that from the time someone complained that 2 layers is simply nonsense for the 100 USD a year license, it took 3.5 days for Jose to come back with an answer that 4 layers are decided for the 100 USD/year license. The actual post announcing that appeared even sooner.
The reason for 4-layers MINIMUM for any commercial design is simple: the 2 core power supply layers for CPU and other high speed electronics. You simply can't make any CPU design without those.
My issue is rather different, my needs are... OLD-fashioned. I need to create BEAUTIFUL schematics, not the Farnell-governed hackjobs, and I made a sketch on how it should work. I will send it later. My other need is, one LARGE sheet, with the beatutiful schematics, all connected. That will require some modification of the current random state libraries. But about that later.
What I was thinking is that I'd like to have one CENTRAL sheet, which would contain everything all the other sheets have, quite literally everything, like the oldr schematics of TV reveivers used to have, you remember that? One piece of paper and it had all the modules, all the components and many times also sketches of what the integrated circuits had inside of them! I just want to have the same thing. But on a bigger piece of paper. Whether I will have to draw it all on one sheet or whether it could be simultaneously on the large sheet and in parts on smaller sheets I don't care at the moment.
What concerns me more is that I want all those blocks, boards and modules on one single layout in one single view into one large panel due to the manufacturing advantage of it. As some of the boards will be facing each other and some may be even placed horizontally, I would have to orient the boards in a way so that the down-facing boards will be actually laid out with SMD components on the top, which means mirrored. Not a big problem now, I was just thinking, how about going beyond Eagle Layout and making Eagle Composer instead? You see my problem with the board area limitations, 10x16cm is less than what the boards will take, even if by a small margin. But individually, the boards before separation (break of v-grooves and milled slots, etc) are way smaller area than 160 square centimeters.
And now to another funny thing: the original limitation of 10x8 and 16x10 centimeter boards were some "euro format boards"...nobody used that for anything anymore. Seriously. I think it would be appropriate to begin scientific board space rationing, do a study or straight upgrate to 100/200/infinite square centimeters area, or maybe 100/240/infinite square centimeters area?
Another problem: would you consider a double-system limitations, where I make a multi-board design and there is a separate dimensional limitation for a board and for the complete board set? Or some kind of a combination of the area limitation system. For example, someone makes a 80x80mm boards and wants to make a panel of 6x2 boards.
How would it work in the schematics: simple, as on the paper, you draw a dashed line around a certain schematic part, connector(s) or pins placed or connected to the dashed line, and above the dashed line the name of the board would be seen in dark brown (or what color you use). That would be AMAZING! Just like in the old days! As a bonus, I would connect inter-board nets in the schematics and not have them displayed in the board layout!
As I invented this feature here, I definitely, definitely want it!!! In the board layout, you would need the weird option of being able to lay-out the board one over-the-other (in background, shadowm whatever), so that you can properly mate elements that emit heat or ate too tall, or there are any holes or mounting parts that should be mating one against each other or you need to route some kind of flexible cable that way. I do NOT want 3D, none at all, I just want to be able to face heatsinks or shielding against each other properly.
Now back to the weird option: While I would be doing the layout with SMT components on the top layer on the lower board, I would want SMT components on the bottom on the upper board, so that I can face the components against each other, use a common heatsink or just face a LED diode with a phototransistor, or mate BNC or other coax connectors, or those hirose board mating connectors. And the weird option is: I want the boards to be placed SMT components UP for all boards, so that I can put them for manuracturing as a single board set, but still want the ability to edit it... Maybe some kind of a switch where the cutout is edited/viewed mirrored/upside-down? But still... duh! I said it before: we need two completely different board views! One is the composer view, where I edit just ONE board, with all the others in some kind of transparency mode, and the boards laying over each other in the way I would want them to be organized in the real life. The other edit mode is the standard mode where the boards would be all laid out in the way they will be exported for manufacturing!
Man, I'm good! When can I buy this feature?
All the boards I'd need would be 240 or 250 square centimeters in total. I'd price it at most at 200USD/year license. Because what I'm doing is rather simple and uses 4-layer board out of convenience and small price difference to a 2-layer board. The 100 USD a year is nice, but I can afford a bit more, but not 500 a year yet. Anyway, you may need to read my post more than once, sorry. This board activity is still semi-professional.
P.S. My expensive coffee costs 7 cents.
