Hello, hope you are doing well.
I am trying to upload a board in EAGLE to Fusion 360, which I have done many times before. When I try to open any of the top-level folders in my organization I get the following error:
Error connecting to Forge, please try again later.
HTTP 502: Error transferring https://contapi.circuits.io/123D-Circuits/ actions/forgeDmProxy/data/v1/projects/
a. YnVzaW5lc3M6ZmFjdHVyZSMyMDIzMDUyNjY0MzgxNzg3Ng/folders/ urn:adsk.wipprod:fs.folder:co.cp-0eb_4SI-8lAv7fTCbNg - server replied: Bad Gateway
Solved by timBXKTC. Go to Solution.
Hi @timBXKTC ,
Hope all is well.
So sorry that you're having trouble.
Are you still able to see this issue?
I tried the workflow, and I cannot reproduce it right now. Do you mind trying again?
So sorry for any inconvenience.
Looking forward to your feedback.
Best regards,
Helen
@HelenChen-ElectronicsQA For what it's worth, I'm seeing this issue now when I try to push from Eagle to Fusion.
Hi @timBXKTC,
Sorry for any inconvenience.
Thank you very much for letting us know.
I will forward back to our development team to see whether any issue was aware of.
BTW, do you mind trying to do the design in Fusion directly? Then you could get the 3D PCB with one-click timely, but no need to use the way to push/pull between EAGLE and Fusion like this. It should save you lot of time.
Hope you have a great day.
Best regards,
Helen
Hello to all,
Today I have the same problem when I try to push my design into Fusion:
HTTP 502: Error transferring https://contapi.circuits.io/123D-Circuits/actions/forgeDmProxy/project/v1/hubs - server replied: Bad Gateway
is there a solution?
Thank you
BR
