Hi there,
When I push my PCB design to Fusion 360 the PCB is an odd copper color instead of the soldermask color. Is there a way to make it look more realistic?
Also, is there a way to delete the default rectangular blocks that appear for the parts that don't have linked 3D models? It would be nice if things like solder jumpers would just show up as solder jumpers and not as red blocks. I also can't seem to find a delete button for the default block online in the 3D package editor.
Thanks!
Update: I found that removing the default blocks was as simple as toggling object visibility in Fusion 360 from the model tree.
I agree this is something that is annoying to me also. I work with a lot of planes which visually make the PCB less appealing. But then I do not want to edit the appearance every time I update the circuit board through the sync.
