Frames in V9.4
Frames in V9.4
JamesLE32J
Message 1 of 14
Frames in V9.4
JamesLE32J
Hiya,
I'm struggling with Frames in V9.4.
If I draw a Frame in Board view I can no longer edit it.  This includes move/resize/copy/delete/anything.  I can't select it at all.
Works as intended in Schematic view.
Any ideas?
Replies (13)
Message 2 of 14
rachaelATWH4
@JamesLE32J wrote:
Hiya,
Any ideas?
Yep, if you need to edit a frame, open it up in 9.3.2 until they get that fixed. It looks like frames got missed from the selection filter in the board.
Best Regards,
Rachael
Message 3 of 14
Pieter.Jan.Van.de.Maele
Hey thanks for your report.
As Rachael points out it seems like we missed frames from the selection filter in the board editor.
What you can do now is force enable them with the CLI option: "SET SELECTTYPES ALL;"
We'll make sure to get this fixed ASAP though.
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
Message 4 of 14
JamesLE32J
As always, Thank You @rachaelATWH4  :).
Thank You too @Pieter.Jan.Van.de.Maele.  Bit worrying if it's been like this for 9 releases (9.3.2 - 9.4.1) and still not addressed.
It's also a bit worrying I've not designed a PCB since 9.3.2! 🙂
Both accepted solutions 🙂
Message 5 of 14
rachaelATWH4
No, it's not been that many releases! 9.3.2 was the last of the 9.3 line, then came 9.4.0 just a few weeks ago where this issue was introduced. Unfortunately nobody spotted this until you posted up yesterday but not before 9.4.1 was released otherwise they would have got this fixed in that release, anyway now they know about it they'll get is sorted pronto I'm sure Smiley Happy
Best Regards,
Rachael
Message 6 of 14
JamesLE32J
Hi @Pieter.Jan.Van.de.Maele,
The Selection filter for Frames is also missing in 9.4.2 in the footprint editor.  I have standard document frames that I use for A4, A3 and A2.  I can't edit these in the footprint editor because I can't select the frame.
Can you log this for fixing in the next release, please?
Message 7 of 14
Ok, thanks!
Message 8 of 14
Do you when this will be fixed? I'm still having issues editing/deleting frames in version 9.5.1.
Message 9 of 14
rachaelATWH4
Hi Aaron,
It seems somehow the frames object has been missed from the symbol editor selection filter! It's been added everywhere else, just not there. I've tested it now and you are right, it's still broken there! I'm pretty sure they'll be able to get this sorted fairly quickly now it's been highlighted!
Best Regards,
Rachael
Message 10 of 14
jorge_garcia
Hi everyone,
I've created a defect report for this. Should be addressed very shortly.
Please let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 11 of 14
steve_jewell
Has this bug been fixed yet?  I'm having this same issue running Eagle 9.6.2 premium.
Message 12 of 14
jorge_garcia
Hi @steve_jewell,
I hope you're doing well. This has been fixed I just looked in the schematic and saw Frame in the selection filter.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Message 13 of 14
ray.jenson
Observer
Observer
Jorge, a year later, and the issue is the same: frames are not editable.
There is no "smash" option like there used to be (akin to the AutoCAD command "Explode") which allowed editing.
Frames are present. Frames are not editable. That is the issue.
Message 14 of 14
jorge_garcia
Hi @ray.jenson ,
I hope you're doing well. Are you pulling in Frames from the library, if you are then these are only editable in the library. In the schematic you can select them by clicking the bottom left corner of the frame.
Let me know if you continue to run into problems
Best Regards,
Jorge Garcia
