Hello!
In an update not that long ago (I think in 8.3) the "flip view" function got added which is useful for the bottom layer.
Is there a way to use it in an ULP? I can´t seem to find it in the documentation.
Edit: A facebook post from Autodesk EAGLE from the 20.10.2017 said that the official name of this feature is "Flip Board".
Solved by jorge_garcia. Go to Solution.
Hi @jeyeffkay,
I hope this message finds you well. If you want it called from a ULP you have to use the
WINDOW FLIP;
To get it back to normal you have to run the command again.
Let me know if there's anything else I can do for you.
Best Regards,
Thank you very much!
I tried to implement it in my ulp:
if(output_selected[7] == 1)
for(int count = 0; count < NumberParts; count++)
WINDOW FLIP;
if(flag == 0)
create_scriptfile(PartPackageBOM[count],PartValueBOM[count],directory,PartName[count],quality,count,PartQuantity[count]);
WINDOW FLIP;
delete_header();
break;
This is a part of my program and here it should create a picture of the board. As you can see, I want to have it flipped and then "reflipped".
But right now it I get an error: "Unknown identifier 'WINDOW'"
Is there something I have missed?
Hi @jeyeffkay,
Some clarification is in order. ULPs on their own can't modify anything so you can't just add in script commands into the ULP. The ULP needs to write the command into a script and then pass that along to electronics on exit to perfrom the operation.
This is the method all ULPS that modify the design follow. They pass a string of commands on exit to EAGLE which then runs those commands.
Best Regards,
Hi @jorge_garcia,
thank you, that is a very helpful information!
If I understand it right, the ULP has to write the 'WINDOW FLIP' command into a script which than gets executed.
Is there documentation on how to do it?
Or ist there a rather simple comand which can do this?
Best regards
Jeyeffkay
Hi @jeyeffkay,
See the ex-run-script.ulp to see how this works. Let me know if there's anything else I can do for you.
Best Regards,
Hi @jorge_garcia,
I am very thankful that you are helping and also sorry that I have that many, and proberbly stupid, questions but I am very confident that this could be my last for now:
Thank you for suggesting the ex-run-script it has shown me how it works.
The Window Flip command now works like charm and does exactly want I want it to.
But now I have the following problem, at least I think that it is whats happening:
The exit() command closes the ulp and opens the scr. But is there a way to only execute the script, running it and than continuing with the ulp?
Because the script should flip the Board and than the ulp should continue doing what it does.
And ideally it should be able to "reexecute" it later.
Best regards
Jonte
Hello @jeyeffkay,
Hey no worries, no such thing as a dumb question. So the way we normally workaround these things is that in script that you generate you have it call the ULP and pass an argument that allows the ULP to continue where it left off. There's no good ways to interrupt execution of the ULP and let it continue where it left off.
Best Regards,
Hi @jorge_garcia,
that sounds very good as a solution. But sadly I couldn´t find how the argument which the script passes to the ULP has to look like in order to continue where it got closed. Is there an example which I could have missed?
Best regards
Jonte
Hi @jeyeffkay,
I hope you're doing well. The argc and argv variables contain the information about the arguments that have been passed to a ULP
int argc
number of arguments given to the RUN command
string argv[]
arguments given to the RUN command (argv[0] is the full ULP file name)
To get an example of how arguments might be passed to a ULP see this example:
RUN cmd-draw-polygon-contours-as-wire SIGNALNAME [FILLING] [Layernumber]
THe first thing after RUN is the name of the ULP then separated by spaces you put in each individual argument. In the example above the arguments are SIGNALNAME, [FILLING] , and [Layernumber]
Let me know if you continue to run into problems.
Best Regards,
Hi @jorge_garcia,
it´s been a while but thank you very much, now everything works like I want it to.
But is there a way of not mirroring the text ot mirror it again? With Window Flip the board gets mirrored, which is good, but there is text on top of it, is there there a way to keep it "normal"?
Best regards,
Jeyeffkay
Hi @jeyeffkay,
I hope you're doing well. Always one of the layer texts will appear mirrored because you are looking at both side with "XRAY VISION". So in that scenario whatever layer is in the back will have it's text mirrored.
Only way to see that text un-mirrored is to flip the board back.
Best Regards,
