flexible pcb
flexible pcb
nehachaurasia1998
Message 1 of 8
flexible pcb
nehachaurasia1998
how can i make flexible pcb in eagle and what board thickness should be?
Replies (7)
Message 2 of 8
albert559pou
Community Visitor
Community Visitor
Layer Stackup and Material Selection:
Decide on the number of layers for your flexible PCB. Common options are single-sided or double-sided flex.
Choose the material for the flexible part of the board. Polyimide (PI) is a popular choice due to its flexibility and thermal stability.
Consider adding a stiffener layer if needed (for connectors or components).
Specify the layer stackup in your design rules.
Component Placement:
Place components on the flexible PCB layout. Ensure they don’t stress the flex area excessively.
Use tear-dropping (tapering of connections) to prevent stress concentration.
Routing:
Route traces carefully to avoid sharp bends or tight corners.
Use curved traces instead of 90-degree angles.
Maintain proper clearances between traces and pads.
Design Rules:
Set up design rules for minimum trace width, spacing, and via sizes.
Define rules specific to flex areas (e.g., minimum bend radius). yourtexasbenefits login
Best Regards
albert559
Message 3 of 8
jorge_garcia
Hi @nehachaurasia1998,
I hope you're doing well. The thickness is going to depend on what your manufacturer can do. For now, there is not tools to help you do flex circuits so you'll have to do it manually by using custom layers. It's not too easy, but possible.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 4 of 8
nehachaurasia1998
Thank you for reply but still i have doubt  this is my first time to make flexible pcb, in my below attached file i have board thickness showing 1.57mm but manufacturer saying board your FPC thikness is 0.18mm how what is FPC thickness nd how to set this in my board??Capture.JPGCapture2.JPG
Message 5 of 8
yourtexasbenifitscfd
Community Visitor
Community Visitor
A flexible PCB (printed circuit board) is a lightweight, bendable electronic circuit built on flexible plastic substrates like polyimide. It is used in compact and dynamic applications such as smartphones, medical devices, automotive systems, and wearables. Flexible PCBs save space, reduce wiring, and improve reliability in tight designs. YourTexasBenefits Login
Message 6 of 8
adamswidely362
Community Visitor
Community Visitor
A flexible PCB (printed circuit board) is a bendable electronic circuit built on thin, flexible substrates like polyimide. It saves space, reduces wiring, and improves durability in compact devices. Flexible PCBs are widely used in smartphones, medical equipment, automotive systems, and wearable technology for reliable, lightweight, and high-performance connections. FloridaBlue Login
Message 7 of 8
newzetnet88
Community Visitor
Community Visitor
Choose the number of layers for your flexible PCB based on design requirements. Common options include single-sided and double-sided flex circuits. Select a suitable material for the flexible section, with polyimide (PI) widely used due to its excellent flexibility and thermal stability. If necessary, add a stiffener layer to support connectors or mounted components. Define the complete layer stackup clearly within your PCB design rules. Visit https://newjetnet.bond/
Message 8 of 8
josephguard430
Community Visitor
Community Visitor
Select the appropriate number of layers for your flexible PCB according to the design needs. Flexible circuits are commonly built as single-sided or double-sided boards. Choose a reliable material for the flexible portion, such as polyimide (PI), which is valued for its durability, flexibility, and heat resistance. When required, include a stiffener to strengthen areas where connectors or components are placed. Ensure the full layer stackup is properly defined in the PCB design rules. Visit https://hctraa.bond/
