EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Feature request: Via stitching/shielding
16 REPLIES 16
Message 1 of 17
6477 Views, 16 Replies
Hi guys,
Very often, I work with 8 layers boards with several GND layers.
In order to shield signals and reduce impedance between the planes, I often place manually a lot of vias for example on a 2mm grid. It is the last step before finishing the PCB. This takes a lot of time, because I have to manually avoid all existing traces and pads.
It would be so nice to have a via stitching option in the polygons which takes a "spacing" parameter and an "avoid pads and traces (even on other layers)" option.
Is such a feature planed?
Victor
16 REPLIES 16
Message 2 of 17
Pieter.Jan.Van.de.Maele
Yes this is planned.
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
Message 3 of 17
Dear Peter,
Do you know when this feature will be able on Eagle ?
Thank in advance for your answer.
BR
Message 4 of 17
jorge_garcia
Hello @Anonymous,
We currently don't have an ETA for this feature although as PJ said we do have plans to implement it. For now you could use the create_drill_line_array.ulp that you can download from here:
http://eagle.autodesk.com/eagle/ulp?utf8=%E2%9C%93&q%5Btitle_or_author_or_description_cont%5D=create_drill_line&button=
This ULP will place vias along an arbitrary path, which can help speed up the process of laying down these vias.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 5 of 17
in reply to: jorge_garcia
Hello @jorge_garcia,
Thank you for your answer. This ULP will help me for the moment.
I hope the Via stitching/shielding will be there for my next project!
Thank you for your support.
BR
Message 6 of 17
Hi, this feature would also be very useful for me as well. Usually in RF designs, you need to flood the top and bottom layers with ground pours, and finally stitch with vias heavily (5-8mm grid). It is a tedious and laborious operation and is a perfect candidate for automation.
Message 7 of 17
any ETA on this feature? I need to use it to avoid ground bounce
Tags (1)
Message 8 of 17
jorge_garcia
Hi @ireshZS62Z,
I hope you're doing well. Unfortunately, there is no update for now, the ULP is the best solution available at this point in time.
Best Regards,
Jorge Garcia
Message 9 of 17
colinNJB25
I have some stitching workarounds in Eagle but I am not finding any for Fusion. Stitching a lines that are .1" apart is almost as tedious as stitching individual vias.
Is RF support even on an existing roadmap? Can you provide a link to the current roadmap so I can judge where the software is heading? I have a bunch of RF work coming up and have used Fusion for a few simple digital circuits but if I have to add another package for RF I want to know well in advance of my needs. Thank you.
Message 10 of 17
jorge_garcia
Hi @colinNJB25 ,
I hope you're doing well. The same methods you used in EAGLE should work in Fusion 360 electronics, namely the ULP I mention further up this thread.
Fusion 360 does not currently post a public roadmap, but what I do know I'll share. For now, what we have is an export to Ansys for signal integrity and RF simulation. We do eventually want to incorporate more advanced RF features but outside of our partnership with Ansys and the technologies that will bring there are no immediate plans to address stitching in Fusion 360.
Hope this helps.
Best Regards,
Jorge Garcia
Message 11 of 17
colinNJB25
Thank you. If the existing pattern command could do rectangles it would solve my immediate problem. It is clever enough to miss components. Creating a grid of vias on a .2" spacing that miss through holes, smd pads,  and traces on any layer in a 4x5 board is very time consuming and not very tolerant of changes. In an ideal world it would be more like the pour command.
I see there is not a public road map. That is too bad, even though it was inaccurate for years the Fusion modeling roadmap really has been very helpful. I was an early adopter of Fusion and am very glad I stuck with it.
Message 12 of 17
christinejohn999
great post
Message 13 of 17
mtl_asm
in reply to: christinejohn999
Message 14 of 17
in reply to: mtl_asm
I’ve use the ULP on several RF designs now and they work perfectly. I still wish there was a tool for this but you can make it work with the ULP.
Message 15 of 17
Via stitching will be released in the March release of Fusion Electronics.
You can get early access to it now as part of our insider program: https://www.autodesk.com/campaigns/fusion-360/insider-program?_ga=2.209938003.756170057.1709510369-8...
Thanks for your patience all!!
Message 16 of 17
Just wanted to let you all know that via stitching is now live in the March update of Fusion Electronics: https://www.autodesk.com/products/fusion-360/blog/march-2024-product-update-whats-new/#electronics
There's quite a few other interesting features like cross highlighting, spice export, removal of unused annular rings, cross-talk for the Signal Integrity extension etc.
Message 17 of 17
Outstanding! I will try it out soon
