@rachaelATWH4 wrote:
I didn't say it was the root cause, just that it's related. It DOES have an effect on what items are seen for selection so MAY improve (or not) the situation (probably not based on subsequent testing).
I'm not going to give you specific cases to show you there is more to that setting than it's name implies. You can easily test it for yourself if you don't believe me, or not, it's up to you, I really don't care either way.
My previous post was a little tongue in cheek because your earlier reply to me was unnecessary, if you didn't think it was relevant then just ignore it, don't make an issue out of it and try to get one over on me.
It's not about you. It's about the facts of the matter and the quality of advice given in these forums. If a productivity tool has non-obvious quirks in features that I use, I want to know about it. And likewise, it's easy for advice like that to become cargo cult advice. Change this option because it might have some subtle effect. Probably. Possibly. Maybe. You can believe it if you want to, or not. I'd rather have a systematic understanding of what something does, though.
So far I have not been able to detect any change in the move tool itself from this option. There are other non-obvious changes in behavior related to it, though. With the option on, when having the move tool selected, pressing esc will revert to the group tool, while the GROUP tool also works as a makeshift move tool. When disabling these options, never of those things are true anymore. So it is for example entirely possible that you pressed esc to cancel a move operation, pressed esc twice by accident so the group tool was selected, tried to move again using the group tool. Since the group tool can also perform a move operation that behaves slightly differently, you may now be thinking that it's the move tool that behaves differently. If you don't keep your eyes plastered on both the work area and toolbar at the same time, you might not even have noticed that the tool selection changed from one tool the other and back again. I might never have noticed this unless I got annoyed enough with how the move tool seemingly random stopped working.
But again, I'm discussing these things because I want to advance an understanding of how the intricacies of Eagle work. Both for myself and other people. It's nothing personal.
If you read my subsequent post you'd see I did further experimentation and determined there is a difference between 8.7.1 and 9.2.2 specifically with via selection, likely related to the changes in the MOVE command which came in 9.1.0.
Rachael
I think nobody is denying THAT!
I'm a regular forum user, and not affiliated with Autodesk, but I like contributing to the forums to learn new things about Eagle. If this post answered your question, feel free to mark it as a solution. If something needs clarification, feel free to ask.
