Hi @nerginer,
I hope you're doing well. Once the Fusion integration is complete, you'll be able to get images like those and better. For the moment you have a couple of options.
If you need the full 3D model, the best option is to use ecad.io to import your EAGLE file and map it to 3D models. From there you can export a STEP model and modify it in Fusion360 to get the rendering you want.
The other option is an old ulp/script combo called eagleup, google it to find the details on it. It's a few years old but I believe it should still work.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Product Support Specialist for Fusion 360 and EAGLE
