I use Eagle 9.6.2 and try to export my design into fusion. All footprints are imported correctly and show a green checkmark. But in fusion everything is shown as grey boxes.
I broke up the link between eagle and fusion and synced as a new asset - same problem. Anything I can do to troubleshoot?
Cheers
Hi @jonny.blaze , this issue is fixed, can you please try again?
Best Regards
Wind
No the problem still persists. None of the components appear.
it works with other designs though, but I dont want to start from scratch.
Hi @jonny.blaze ,
Can you try below steps?
Make some changes in 2d side and then push again to regenerate the 3d model, or in pcb3d command dialog, uncheck all components and push and then push again with all components checked.
Best Regards
Wind
Where can I find the pcb3d command dialog? I only get these two, where I cannot uncheck anything.
Any other help?
I found out, that replacing "Edit custom 3D package" helps. But i dont want to do this on 300 components. Even this doesnt always work. I shift the component on Z axis by 0.01mm and pressing "OK" after the comment dialog doesnt do anything.
Running from bug to bug. Really annoying.
