08:11 AM
My schematic has a 25 pin D-Sub. The pins are assigned to different supplies such as +/-15V, AGND, and GND.
I defined the pin using label in the order of 1,2,3,....25. Meanwhile, I add the supplies to the pins. For example, I add +15V to pin 8. Please find the attached screenshot.
Then, I got error message "Supply pin +15V overwitten with more than one signal".
If this message will impact the final PCB, can I ignore it?
What is the correct way to do?
Dawn
