I used copper pour to complete a PCB board, but I got a width error at the edge of the boundary, Since it is no the error of width of the wires, I don't know what are the problems and how to remove it. Please find the attached screenshot.
Please advise.
Dawn
Solved by rachaelATWH4. Go to Solution.
What line width have you specified for your copper pours? Look in the properties for the polygon and I suspect you will find a line width less than your DRC minimum.
Best Regards,
Rachael
I am having the same issue with the top and bottom layer. I get two width errors and they are a
@rachaelATWH4wrote:
@Anonymous wrote:I used copper pour to complete a PCB board, but I got a width error at the edge of the boundary, Since it is no the error of width of the wires, I don't know what are the problems and how to remove it.
Best Regards,
Rachael
I am getting the same error for the top and bottom layers. It shows up as a red and blue line on the top and side of the board. I looked at my properties of the polygon and the width is set to 6. The minimum width set in DRC is 6 mil also. If I set the polygon size higher the error is still there. Any advice?
Check the minimum width mentioned in the net classes. You change as per your manufacturer, and update the same here. if your track width is greater than this, error won't show.
Anyways if your manufacturer can take care of the trace width specified by you, you need not worry about this.
