Error during ERC
Error during ERC
jer.rodrigues
Error during ERC
jer.rodrigues
Hello
During the ERC, I got a warning message "No pins on net N$22".
When I click on the warning message, it doesn't point to any parts/links/... and I searched for a missing things, but I did not find anything.
On the generated PCB, no trace of N$22 indication.
How could I found or fix this warning message please ?
jorge_garcia
Hello @jer.rodrigues ,
I hope you're doing wells. The warning implies that there is a floating net in the schematic. Try the following in the schematic CLI type
Show @ N$22
Does anything get framed? If nothing, then means there is a phantom net in the XML. It won't harm anything so you can ignore it.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
jer.rodrigues
Hello Jorge, thanks for your quick answer.
unfortunately, nothing is shown with this command, I received this popup only, but no wire is framed... So I will keep it as is... thanks
