2019 Macbook Pro (Intel i9 + 32GB memory)
MacOS 11.6.8 Big Sur
EAGLE 9.6.2
Looking through the forums, lag in EAGLE's layout editor after 7.X versions seems to be nothing new (I've been using 7.7 for a long time and only recently upgraded to 9.6.2). So far my experience has been positive, but I recently discovered a challenging scenario. I only experience lag in the layout editor when I use my macbook pro's display. Normally, I use to external monitors, and experience no lag in the editor at all, but while traveling recently (without my monitors) I was frustrated to find that there was suddenly lag in my workflow.
I've done a few tests to better understand this bug, and I've found the following:
- Complexity of the design does not matter (2 layer layout with 1 component is still lagging)
- Lag only occurs on the macbook pro's built-in display (I've tested connecting only one monitor and leaving the macbook pro open; lag when the EAGLE layout window is on the macbook pro's display, and then as soon as I drag that same window to the external monitor, no lag at all)
- Turning off live DRC and board shape detection make no difference (same lag feel with these turned off)
Let me know if there's anything else I can try or details I can give to help the EAGLE team better understand this bug. Luckily, I mostly use EAGLE with my external displays, but this is very frustrating when I'm traveling.
