I've used Eagle 5, 6, and 7 for many years on Fedora Linux with few problems. I just installed Eagle 8.0.2 on Fedora 25, and the menu bars and menus don't work properly. The menu titles on the menu bars are run together with no spacing:
I can live with that, but when I click on the menu title, the pop-down menu is just a blank grey rectangle:
Fedora 25 uses Qt 5.7.1. I have not had this problem with other Qt5 applications.
Solved by jorge_garcia. Go to Solution.
Hi @Anonymous,
Thank you for your participation and for bringing this up. Let's first make sure and confirm what Qt libraries EAGLE itself is using, you mention that Fedora uses 5.7.1 however EAGLE should be using 5.6.2 which it ships with.
Using a terminal cd to the EAGLE's directory and type:
ldd eagle
This will tell you what libraries EAGLE is using, please confirm the Qt version being used and let me know. In any case I have filed a report with the developers so that they are aware of the issue.
Let me know if there's anything else I can do for you.
Best Regards,
I am having the same issue as @Anonymous, but I'm running on Solus.
Here's the output of ldd
ignormies@comp /opt/eagle $ ldd eagle | grep Qt libQt5Widgets.so.5 => /opt/eagle/lib/libQt5Widgets.so.5 (0x00007fdf0074f000) libQt5Network.so.5 => /opt/eagle/lib/libQt5Network.so.5 (0x00007fdf003ef000) libQt5PrintSupport.so.5 => /opt/eagle/lib/libQt5PrintSupport.so.5 (0x00007fdf00182000) libQt5Gui.so.5 => /opt/eagle/lib/libQt5Gui.so.5 (0x00007fdeff990000) libQt5Xml.so.5 => /opt/eagle/lib/libQt5Xml.so.5 (0x00007fdeff755000) libQt5Core.so.5 => /opt/eagle/lib/libQt5Core.so.5 (0x00007fdeff03e000) libQt5WebEngine.so.5 => /opt/eagle/lib/libQt5WebEngine.so.5 (0x00007fdefedf5000) libQt5WebEngineCore.so.5 => /opt/eagle/lib/libQt5WebEngineCore.so.5 (0x00007fdefa3df000) libQt5WebEngineWidgets.so.5 => /opt/eagle/lib/libQt5WebEngineWidgets.so.5 (0x00007fdefa1ab000) libQt5WebChannel.so.5 => /opt/eagle/lib/libQt5WebChannel.so.5 (0x00007fdef9f8e000) libQt5WebSockets.so.5 => /opt/eagle/lib/libQt5WebSockets.so.5 (0x00007fdef9d65000) libQt5Quick.so.5 => /opt/eagle/lib/libQt5Quick.so.5 (0x00007fdef9774000) libQt5Qml.so.5 => /opt/eagle/lib/libQt5Qml.so.5 (0x00007fdef9179000) libQt5Positioning.so.5 => /opt/eagle/lib/libQt5Positioning.so.5 (0x00007fdef8f3a000) libQt5XcbQpa.so.5 => /opt/eagle/lib/libQt5XcbQpa.so.5 (0x00007fdef8bf1000) libQt5DBus.so.5 => /opt/eagle/lib/libQt5DBus.so.5 (0x00007fdef0591000)
Solus is still on Qt5.6.2 so that should not be the issue
ignormies@comp/ $ eopkg info qt5-base Installed package: Name : qt5-base, version: 5.6.2, release: 3 Summary : Cross platform application and UI framework Description : Cross platform application and UI Framework Licenses : FDL-1.3, GPL-2.0, LGPL-2.1, LGPL-3.0
When I run eagle through the console I get the following messages, which might help to find the issue
ignormies@comp ~ $ /opt/eagle/eagle /opt/eagle/eagle: /opt/eagle/lib/libcrypto.so.10: no version information available (required by /opt/eagle/eagle) /opt/eagle/eagle: /opt/eagle/lib/libdbus-1.so.3: no version information available (required by /usr/lib/libavahi-client.so.3) QGtkStyle could not resolve GTK. Make sure you have installed the proper libraries. QGtkStyle could not resolve GTK. Make sure you have installed the proper libraries. QGtkStyle could not resolve GTK. Make sure you have installed the proper libraries. Installed Qt WebEngine locales directory not found at location /opt/eagle/translations/qtwebengine_locales. Trying application directory... Qt WebEngine locales directory not found at location /opt/eagle/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct. [0315/203424:WARNING:resource_bundle.cc(291)] locale_file_path.empty() for locale Qt WebEngine ICU data not found at /home/eagle/Qt/5.6/gcc_64/resources. Trying parent directory... Qt WebEngine ICU data not found at /home/eagle/Qt/5.6/gcc_64. Trying application directory... Installed Qt WebEngine locales directory not found at location /home/eagle/Qt/5.6/gcc_64/translations/qtwebengine_locales. Trying application directory... Qt WebEngine locales directory not found at location /opt/eagle/libexec/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct. Qt WebEngine resources not found at /home/eagle/Qt/5.6/gcc_64/resources. Trying parent directory... Qt WebEngine resources not found at /home/eagle/Qt/5.6/gcc_64. Trying application directory... [0315/203424:WARNING:resource_bundle.cc(291)] locale_file_path.empty() for locale
You're right, ldd shows it is using the libraries in the lib directory in the install path, not the Fedora 25 Qt. As an experiment, I tried to get it to use the Fedora 25 Qt, but unsurprisingly that doesn't work (5.7 vs. 5.6).
It looks like this may be due to a missing Qt "style" library; it appears to be using QGtkStyle but some relevant files are apparently not present. Here's the output from running it, with the style warnings on lines 3 through 5:
[eric@localhost eagle-8.0.2]$ ./eagle ./eagle: /home/eric/eagle/eagle-8.0.2/lib/libdbus-1.so.3: no version information available (required by /lib64/libavahi-client.so.3) QGtkStyle could not resolve GTK. Make sure you have installed the proper libraries. QGtkStyle could not resolve GTK. Make sure you have installed the proper libraries. QGtkStyle could not resolve GTK. Make sure you have installed the proper libraries. Installed Qt WebEngine locales directory not found at location /home/eric/eagle/eagle-8.0.2/translations/qtwebengine_locales. Trying application directory... Qt WebEngine locales directory not found at location /home/eric/eagle/eagle-8.0.2/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct. [0315/230550:WARNING:resource_bundle.cc(291)] locale_file_path.empty() for locale Qt WebEngine ICU data not found at /home/eagle/Qt/5.6/gcc_64/resources. Trying parent directory... Qt WebEngine ICU data not found at /home/eagle/Qt/5.6/gcc_64. Trying application directory... Installed Qt WebEngine locales directory not found at location /home/eagle/Qt/5.6/gcc_64/translations/qtwebengine_locales. Trying application directory... Qt WebEngine locales directory not found at location /home/eric/eagle/eagle-8.0.2/libexec/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct. Qt WebEngine resources not found at /home/eagle/Qt/5.6/gcc_64/resources. Trying parent directory... Qt WebEngine resources not found at /home/eagle/Qt/5.6/gcc_64. Trying application directory... [0315/230550:WARNING:resource_bundle.cc(291)] locale_file_path.empty() for locale
Another software bug becomes apparent from that output. Eagle is looking for files in /home/eagle, which it shouldn't do unless it's been installed into /home/eagle, or otherwise configured to use /home/eagle. In this case I installed it under my home directory to give it a try, but normally I install it somewhere else entirely.
Best regards,
Eric
Hi @Anonymous @Anonymous,
Thanks guys for posting your error logs. We release V8.1.0 a few days ago and there are a few bugfixes there. If you still get the same behavior look in the Readme. Depending on the hardware and distribution some users may have to switch between hardware and software rendering for EAGLE.
If it's still not working right, then repeat the ldd experiments with 8.1.0. Seeing if anything is different will help us get to the bottom of this.
Just so that everyone knows, our current plan is to officially support 4 main distros (Ubuntu, OpenSuse, Fedora, and CentOs) EAGLE will be tested on these distributions since they represent the three main families of Linux distros and our commonly used in our industry. With that said even though distros outside of those four will not be "officially" supported, the support team will do everything we can to help users get EAGLE running on their distro of choice(I'm talking to you DeBrycelsRight).
Please let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Sorry, I forgot to mention that I was getting these issues on 8.1.0 as well as 8.0.2. These logs were generated with 8.1.0.
HI @Anonymous,
This solution popped up in another thread. It may be applicable to your situation as well. Give it a shot and let me know if this works for you.
Ok - so now the procedure that got eagle 8 to work for me on Fedora 25:
Go to /opt/eagle/lib (or wherever eagle got installed) and keep the following libraries there from the eagle distribution:
-rwxr-xr-x 1 apataki users 25047021 Feb 22 19:07 libicudata.so.56
-rwxr-xr-x 1 apataki users 3297615 Feb 22 19:07 libicui18n.so.56
-rwxr-xr-x 1 apataki users 2007793 Feb 22 19:07 libicuuc.so.56
-rwxr-xr-x 1 apataki users 5323496 Feb 22 19:07 libQt5Core.so.5
-rwxr-xr-x 1 apataki users 522952 Feb 22 19:07 libQt5DBus.so.5
-rwxr-xr-x 1 apataki users 6211736 Feb 22 19:07 libQt5Gui.so.5
-rwxr-xr-x 1 apataki users 1439520 Feb 22 19:07 libQt5Network.so.5
-rwxr-xr-x 1 apataki users 258288 Feb 22 19:07 libQt5Positioning.so.5
-rwxr-xr-x 1 apataki users 446616 Feb 22 19:07 libQt5PrintSupport.so.5
-rwxr-xr-x 1 apataki users 4163632 Feb 22 19:07 libQt5Qml.so.5
-rwxr-xr-x 1 apataki users 4130952 Feb 22 19:07 libQt5Quick.so.5
-rwxr-xr-x 1 apataki users 119104 Feb 22 19:07 libQt5WebChannel.so.5
-rwxr-xr-x 1 apataki users 74746560 Feb 22 19:07 libQt5WebEngineCore.so.5
-rwxr-xr-x 1 apataki users 298120 Feb 22 19:07 libQt5WebEngine.so.5
-rwxr-xr-x 1 apataki users 212768 Feb 22 19:07 libQt5WebEngineWidgets.so.5
-rwxr-xr-x 1 apataki users 169064 Feb 22 19:07 libQt5WebSockets.so.5
-rwxr-xr-x 1 apataki users 6782152 Feb 22 19:07 libQt5Widgets.so.5
-rwxr-xr-x 1 apataki users 1347384 Feb 22 19:07 libQt5XcbQpa.so.5
-rwxr-xr-x 1 apataki users 243568 Feb 22 19:07 libQt5Xml.so.5
and move the following out of the way (or remove them):
-rwxr-xr-x 1 apataki users 74192 Feb 22 19:06 libavahi-client.so.3
-rwxr-xr-x 1 apataki users 52792 Feb 22 19:06 libavahi-common.so.3
-rwxr-xr-x 1 apataki users 2049624 Feb 22 19:06 libcrypto.so.10
-rwxr-xr-x 1 apataki users 274208 Feb 22 19:06 libdbus-1.so.3
-rwxr-xr-x 1 apataki users 143920 Feb 22 19:06 libEGL.so.1
-rwxr-xr-x 1 apataki users 13632 Feb 22 19:06 libfreebl3.so
-rwxr-xr-x 1 apataki users 655032 Feb 22 19:06 libfreetype.so.6
-rwxr-xr-x 1 apataki users 51336 Feb 22 19:06 libgbm.so.1
-rwxr-xr-x 1 apataki users 484424 Feb 22 19:06 libgcrypt.so.11
-rwxr-xr-x 1 apataki users 186440 Feb 22 19:06 libglapi.so.0
-rwxr-xr-x 1 apataki users 690392 Feb 22 19:06 libgnutls.so.26
-rwxr-xr-x 1 apataki users 22432 Feb 22 19:06 libgthread-2.0.so.0
-rwxr-xr-x 1 apataki users 348112 Feb 22 19:06 libjasper.so.1
-rwxr-xr-x 1 apataki users 269480 Feb 22 19:06 libjpeg.so.62
-rwxr-xr-x 1 apataki users 22160 Feb 22 19:06 libplc4.so
-rwxr-xr-x 1 apataki users 18016 Feb 22 19:06 libplds4.so
-rwxr-xr-x 1 apataki users 199672 Feb 22 19:06 libsmime3.so
-rwxr-xr-x 1 apataki users 465736 Feb 22 19:06 libssl.so.10
-rwxr-xr-x 1 apataki users 71440 Feb 22 19:06 libtasn1.so.3
-rwxr-xr-x 1 apataki users 5160 Feb 22 19:06 libX11-xcb.so.1
-rwxr-xr-x 1 apataki users 13560 Feb 22 19:06 libXau.so.6
-rwxr-xr-x 1 apataki users 19208 Feb 22 19:06 libxcb-dri2.so.0
-rwxr-xr-x 1 apataki users 115640 Feb 22 19:06 libxcb-glx.so.0
-rwxr-xr-x 1 apataki users 46872 Feb 22 19:06 libxcb-render.so.0
-rwxr-xr-x 1 apataki users 14176 Feb 22 19:06 libxcb-shape.so.0
-rwxr-xr-x 1 apataki users 33152 Feb 22 19:06 libxcb-xfixes.so.0
-rwxr-xr-x 1 apataki users 13760 Feb 22 19:06 libXcomposite.so.1
-rwxr-xr-x 1 apataki users 44040 Feb 22 19:06 libXcursor.so.1
-rwxr-xr-x 1 apataki users 13632 Feb 22 19:06 libXdamage.so.1
-rwxr-xr-x 1 apataki users 81992 Feb 22 19:06 libXext.so.6
-rwxr-xr-x 1 apataki users 22552 Feb 22 19:06 libXfixes.so.3
-rwxr-xr-x 1 apataki users 68496 Feb 22 19:06 libXi.so.6
-rwxr-xr-x 1 apataki users 1425384 Feb 22 19:06 libxml2.so.2
-rwxr-xr-x 1 apataki users 43528 Feb 22 19:06 libXrandr.so.2
-rwxr-xr-x 1 apataki users 43392 Feb 22 19:06 libXrender.so.1
-rwxr-xr-x 1 apataki users 260136 Feb 22 19:06 libxslt.so.1
-rwxr-xr-x 1 apataki users 26584 Feb 22 19:06 libXtst.so.6
-rwxr-xr-x 1 apataki users 22192 Feb 22 19:06 libXxf86vm.so.1
Make sure that the Fedora packages for these libraries are installed on the system. After this, eagle starts up for me and is usable.
Please accept as solution if my post fully resolves or you issue, or reply with additional details if the problem persists.
Best Regards,
confirmed fix works on fedora 25 - you're awesome, @Anonymous !
removed the following libraries from /eagle/eagle8.1.0/lib/
libcrypto.so.10
libdbus-1.so.3
libEGL.so.1
libfreebl3.so
libfreetype.so.6
libgbm.so.1
libgcrypt.so.11
libglapi.so.0
libgnutls.so.26
libgthread-2.0.so.0
libjasper.so.1
libjpeg.so.62
libplc4.so
libplds4.so
libsmime3.so
libssl.so.10
libxcb-dri2.so.0
libxcb-glx.so.0
libxcb-render.so.0
libxcb-shape.so.0
libxcb-xfixes.so.0
libXcomposite.so.1
libXcursor.so.1
libXdamage.so.1
libXext.so.6
libXfixes.so.3
libXi.so.6
libxml2.so.2
libXrandr.so.2
libXrender.so.1
libxslt.so.1
libXtst.so.6
libXxf86vm.so.1
Confirmed fix for Solus, although I had to copy libcrypto and libssl back in from my system's lib directory
