EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Dynamically name pins?
1 REPLY 1
toby
280 Views, 1 Reply
I am creating a new library of power supply parts.  Do I need to create a separate symbol for every voltage (i.e. create a symbol with a supply pin called +7.2V and one with a supply pin called +8.4V) or is there a way of having one symbol and dynamically naming the supply pin from a device parameter for each device/voltage I want to create?
Tags (3)
1 REPLY 1
jorge_garcia
in reply to: toby
Hello @toby ,
For now you have to create a separate supply symbol for each rail you want. They can not be dynamically renamed on the schematic.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
