Hi
@RitchieFromParis,
I hope you're doing well. In the new version of EAGLE you can still use your legacy CAM job, the key point is to not convert the legacy CAM job to the new CAM processor. When you open your CAM job just run it as is.
With that said the CAM processor in EAGLE 9 can still do this. Open the CAM processor and then click on the word Drill on the left top. That is the configuration for the drill section and you can set it to 2 4, also make sure to change the units to inches otherwise the numbers are going to be off.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Product Support Specialist for Fusion 360 and EAGLE
