Drill file output EXCELLON_24 with Eagle 9 on Mac OSX
RitchieFromParis
RitchieFromParis
Hi all
I have a job to do but with a old CAM FILE with EXCELLON_24 drill file.
How can do that ?
I try to Open legacy function but not works.
Thanks by advance
jorge_garcia
Hi @RitchieFromParis,
I hope you're doing well. In the new version of EAGLE you can still use your legacy CAM job, the key point is to not convert the legacy CAM job to the new CAM processor. When you open your CAM job just run it as is.
With that said the CAM processor in EAGLE 9 can still do this. Open the CAM processor and then click on the word Drill on the left top. That is the configuration for the drill section and you can set it to 2 4, also make sure to change the units to inches otherwise the numbers are going to be off.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
RitchieFromParis
Hi Jorge
Thanks again for your precious help.
I know I can use the legacy cam but it's very very very very long and I have the color wheel during the job.
I didn't find the possibility to make EXCELLON_24 device with EAGLE 9, if you are a tutorial or something else it will be welcome's for me.
Best and thanks again.
Ritchie
jorge_garcia
I hope you're doing well. See the attached imagePay special attention to units and the Format SpecifierPay special attention to units and the Format Specifier
This is all the setup you have to do to get an equivalent Excellon file.
Best Regards,
Jorge Garcia
RitchieFromParis
Hi Jorge and thanks for your reply I appreciate.
In fact, my question is how can do a "DEVICE" ECELLON_24 because I don't have choice in the pict you sent me.
See the old CAM output file with EXCELLON_24 I have.
Best and sorry for disturbing.
Best
Ritchie
jorge_garcia
No worries, in the new CAM processor you can't edit the old CAM jobs. Those have to be run as is. The picture I gave in my last post was to achieve the same result using the new CAM processor.
Best Regards,
Jorge Garcia
RitchieFromParis
Hi Jorge, thanks your reply...
I note that, I think I will use a old version of EAGLE.
Do you have a ftp link for download a old version ?
Many thanks to you Jorge.
Best
Ritchie
