EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Creation of Gerber file for the first time
2 REPLIES 2
mailLA8VL
331 Views, 2 Replies
I have created a PCB using Eagle and want to place an order at PCBway. Now I tried to create a Gerber file for the first time. When I run the CAM processor using default settings, the output folder contains different folders (Assembly, DrillFiles, GerberFiles, ODBFiles). Which file do I need here to do the order?
2 REPLIES 2
jorge_garcia
in reply to: mailLA8VL
Hi @mailLA8VL,
I hope you're doing well. You will actually need all of the files. For most board houses the Drill files and Gerber files are enough. It's not a single gerber that you need but rather the complete collection of gerber files that represent your manufactured board.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
mailLA8VL
in reply to: jorge_garcia
Thanks a lot Jorge.
I found also a helpful link on PCBway that explains the creation:
https://www.pcbway.com/helpcenter/generate_gerber/Generate_Gerber_files_in_Eagle.html
