Create Schematic Symbol with Pin Names And Pin Numbering
markus.langerWE75H
markus.langerWE75H
in Library Editor I want to create a symbol with pin names and also pin numbering like shown in p1. However, I find only a way to show and edit the pin names like in p2. How is it possible to number pins like in p1?
Thanks for helping me,
Markus
Yura.Ivanov.VLuki
the manual is explained. Select the number and function display (both) in the contact properties.
one-of-the-robs
The pad numbers never appear on the symbol in the symbol editor because they don't exist until the connections are mapped. They become visible in the device editor once that's been done (providing you have the right visibility as Yura says)
markus.langerWE75H
Thanks for your quick reply. I had to create a package first and put it together with the symbol into a device. Then when I use the device there is pin numbering. So everything is fine.
markus.langerWE75H
Yes, I already discovered this a few minutes ago 😉
