EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Copying one via maintains name; copying multiple ones renames to new net
8 REPLIES 8
Message 1 of 9
ted.yapo
1615 Views, 8 Replies
ted.yapo
Eagle 9.4.1/Linux
I have some vias stitching GND layers on a multi-layer PCB. If I copy a single one of these GND vias, I get a new GND via. If I copy two or more of them at once, they end up on a new net called GND1. Subsequent copies end up on GND2, etc. None of these are on the original GND net, so they must be re-named. Or, in my case, not renamed, resulting in some bad boards.
Why the inconsistency between the copying single and multiple items? I find it confusing and error prone.
More to the point: is there a better way to copy a number of vias? It would be very convenient, since they're not always in a circle or line that can be done with the pattern tool.
Eagle 9.4.1/Linux
8 REPLIES 8
Message 2 of 9
Timon-MESO
in reply to: ted.yapo
Timon-MESO
This is a very annoying behaviour indeed. I've fallen victim to that many times, I would love to see that change.
Creating larger arrays of vias is really hard this way.
Message 3 of 9
edwin.robledo
edwin.robledo
Hi ted.yapo,
Thank you for posting in the Autodesk EAGLE forum. I'm going to report this to our developing team.
In the meantime, there is a useful ULP to draw patterns of Vias and Holes. Please take a look at this recent post.
Best Regards,
Ed
Edwin Robledo
Tech Marketing Manager
Hi ted.yapo,
Best Regards,
Ed
Edwin Robledo
Message 4 of 9
alexA3RDM
in reply to: edwin.robledo
alexA3RDM
Was there ever any movement on this? I'm having a helluva time placing GND vias on a board that's already weeks late....
Message 5 of 9
grahamUTKMN
in reply to: alexA3RDM
grahamUTKMN
This does seem an odd feature to me too.
G
G
Message 6 of 9
jorge_garcia
in reply to: grahamUTKMN
jorge_garcia
Hi @grahamUTKMN,
No new movement on this for now. If you need to have a large number of vias with the same net name this can be handled using the command line.
VIA 'GND' <enter key>
Every via you place will now be named GND, it's a very easy way to get a large number of vias with the same net name placed while still affording complete control over placement.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Hi @grahamUTKMN,
Best Regards,
Jorge Garcia
Message 7 of 9
in reply to: jorge_garcia
This works if you are placing a new Via. It does not work when you do a group copy even if the original array of vias you are copying were all connected to ground. The original problem remains.
Message 8 of 9
csvanberg
csvanberg
I too would like to see this problem gone, amongst a few others.
Ground vias should really have their own layer, to make it possible to turn off those separately, for error checking etc.
Message 9 of 9
jorge_garcia
jorge_garcia
Hi Everyone,
I hope you're doing well. Unfortunately, no movement on this as of yet.
Best Regards,
Jorge Garcia
Hi Everyone,
Best Regards,
Jorge Garcia
