EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
command to set ignore obstacles as default
1 REPLY 1
cambazz
408 Views, 1 Reply
cambazz
Observer
Observer
Is there any command we can add to eagle.scr, so ignore obstacles while routing is the default behaivor?
Best Regards,
C.A.
Best Regards,
C.A.
1 REPLY 1
mtl_asm
in reply to: cambazz
mtl_asm
hi,
you can use
set obstacle_mode ignore;
best
s
hi,
you can use
best
s
