EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Can part Attributes be edited in Inspector?
21 REPLIES 21
Message 1 of 22
scott
1138 Views, 21 Replies
I've selected a group of parts, all of the same type and all having the same exact Attribute values, and I want to edit those Attributes on those parts at the same time, to save time.  I can select the parts and see the Attributes in Inspector.  When I double-click an Attribute value, I can change it, but the change doesn't stick and the value reverts to its original state.  Am I doing something wrong?
Scott
21 REPLIES 21
Message 21 of 22
4ckatro
in reply to: scott
I created some screenshots. BTW, changing attributes in Inspector was working for a while. But there was a sudden change and now does not work as it is described before.
Message 22 of 22
jorge_garcia
in reply to: scott
Hi @4ckatro,
I hope you're doing well. I've reported this to our developers in the meantime you can use the attrib-add.ulp to add attributes to a group of components. I've attached it.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Technology Administrators
