Can I hide the bundled Managed Libraries from the Control Panel?
scott
scott
There was a thread related to this question, but it's over a year old and thus is for an older version of Eagle, so I'm asking anew: I'd like to hide the long list of bundled libraries from the Managed Libraries list in Control Panel.  The Library Manager doesn't affect this, from what I can tell.  Is there a way?  I only use my own libraries, so the bundled ones are just clutter.
Scott
david.mellis
You can delete the libraries. In the library manager, remove them from use, then in the "available" tab, select them and hit the delete button. This will remove the local copies, so they won't appear in the control panel any more.
We're planning to add a way for you to remove all the bundled libraries in one action, and specify that they shouldn't be re-installed when update to new versions of EAGLE.
