I found out some problem with renaming components in my PCB. I tried it in new schematic - 2 connectors (5 pins) connected together in schematic, routed in PCB and then change the name of connector from J1 to J20. Traces on the renamed connector have DRC error. When you ripup one trace and try to wire new one it can´t be connected to the pad but the airwire is still there.
