Bug: Change name - DRC error
havlicek6TH3H
havlicek6TH3H
I found out some problem with renaming components in my PCB. I tried it in new schematic - 2 connectors (5 pins) connected together in schematic, routed in PCB and then change the name of connector from J1 to J20. Traces on the renamed connector have DRC error. When you ripup one trace and try to wire new one it can´t be connected to the pad but the airwire is still there.
Pieter.Jan.Van.de.Maele
Hey thanks for reporting this.
This looks very similar to a bug that was resolved in the past. It might be a variation though. Which EAGLE version are you currently running?
Thanks!
PJ
EDIT: I could reproduce this issue in the latest version of EAGLE. Seems like a regression. We will try to fix this ASAP.
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
havlicek6TH3H
I try to use the newest version of Eagle so the version is 8.5.
Best Vojta
