BUG after updating of Fusion360. Error pushing to fusion: .
I have a returning issue about pushing design to Fusion360 from Eagle. I could use successfully the push to fusion option like 40 times on this design. But now after applying plenty of modifications on the board I got an error. I am working on a complex design and I cannot share the design files. However the error message does not help me to figure out what is the problem. There is a similar post in the forum, but it is abandoned, other user reported this issue is really annoying and no one bat an eye...
So I get the error: "Error pushing to Fusion: . "
But I do not know where to start to find the error. As I mentioned, the design is pretty complex, with ~500 components, all of them are having 3D models.
If I remove the fusion link and create a new one I got the same error. If I try to push two times, in the second try I get another nonsense error:
Where can I check what causes the problem?
Any help would be welcomed.
Rob
UPDATE:
I deleted everything from schematic and layout, removed fusion link, created new fusion 360 design and still same error:
UPDATE 2:
I opened a second project, where I didnt do any modification and pushing does not work... Same error. So probably after applying an update to Fusion this feature got broken on my case...
